Pioneer 811S........ Help ............ Help..............
KK
I have a Pioneer 811S with a PB-10 Subwoofer.
My question is:
The Bass is not clean or tight, should I turn on the PLS level on the 811S?
What's Midnight Mode???
Any help would be appreciated.
Thanks,
KK
G.DawG
Are you using a subwoofer cable or just an RCA cable? That may be your problem. I own the JBL PB-10 as well and mine has very tight bass response. Midnight mode is just dolby digital which limits the noise and clears dialog, it also increases bass response.
KK
I'm using Monster Subwoofer Cable 400.
Maybe I can switch it to Loudness Mode??
Any Ideas??
Many Thanks,
KK
