Receiver w/ AC outlet(s)
Username: Bluemando
I'd like some recommendations for a budget receiver or integrated amp that has at least one AC outlet on the back. Incredibly the remote control of my Sony CD player doesn't have an on/off switch, so I'm thinking that the AC outlet would solve the problem, allowing me to plug the CD player into the AC outlet so that I could turn the CD player off by simply shutting down the receiver (or integrated amp) with its remote. Budget = $350 or less.
Username: Jan_b_vigne
Dallas, TX
Post Number: 11957
The outlet will have to be a "switched" type. Most aren't. It would be easier and cheaper to add a power strip with a switch but you'll have to switch it manually.
Username: Bluemando
??? If a power strip requires me to turn-off (i.e. switch-off?) the CD manually that would defeat my purpose, no? I'm listening to CD's at night in bed and I want to shut down everything without having to get out of bed :o) Thanks for pointing out that the AC outlet must read "switched." Maybe an integrated amp would be more likely to have that? I'm rather ambivalent about listening to the local FM stations anyway.
Thanks
Johern
Username: Nuck
Post Number: 9537
jc, think about 'the clapper'.
Sorry buddy, best I can do right now.
Username: Stu_pitt
Irvington, New York USA
Post Number: 2374
What happens if he's watching late night talk shows and the audience applaudes?
Does the Clapper shut everything off?
Username: Nuck
Post Number: 9540
What happens if I got 'the clap'?. Does it just come and go?
So many questions, so much time...
Username: Bluemando
Thanks for the jokes guys... I needed that! (really, I got a chuckle out of em) For the record, I think I may have found a couple of receivers that might work for me: Marantz SR4328 (80w, x2) and Onkyo TX8522 (100w x2) Both have switched AV in back. Which do you think would give me a nice, warm, lush, and glowing sound at low to moderate volume? - (mainly classical music, but I do get into 70's rock if and when I'm sipp'n scotch). Hmmm... "warm," "lush," "glowing"... yeh, I'm still talking music.
