Silver Member Username: Xfacta82Post Number: 109 Registered: Mar-07 | Sony SA-W2500 100-Watt Performance Line Subwoofer I can get it for 79.99 Is it worth the money? |
Platinum Member Username: Jan_b_vigneDallas, TX Post Number: 11907 Registered: May-04 | . I don't know of a $79.99 "subwoofer" that is a real subwooofer or that is worth owning. Do not pass Go. Do not spend $79.99 plus tax. |
Gold Member Username: Arande2Rattle your ... Missouri Post Number: 2757 Registered: Dec-06 | The only way to even get any kind of performance at all with that money is to have bought 6 of the EHQS series 12" drivers while they were in stock and mounted them in an infinite baffle, and that's assuming you have some wood lying around along with some old stereo receiver. Ah, whatever. It's really your decision in the end anyway. We only guide the decision. |
Silver Member Username: WattsssupBarrie, ON Canada Post Number: 166 Registered: Aug-06 | Seth, what kind of performance do you want from your sub? If all you want is some rumble while watching movies, than perhaps this will be worth the money to you. If you want it to reproduce low frequencies fairly accurately for music, Sony would not be the product of choice. And unfortnutely, it would cost a bit more than $80. Is it worth it? Depends on your expectations. Regards, Marc |
Silver Member Username: Xfacta82Post Number: 113 Registered: Mar-07 | i just want some rumble for movies and videogames. I dont listen to music on my surround sound. |
Platinum Member Username: Jan_b_vigneDallas, TX Post Number: 11913 Registered: May-04 | . What else could you do with $79.99 plus tax? Surely you could do something better than waste it on this "subwoofer". |
Silver Member Username: WattsssupBarrie, ON Canada Post Number: 167 Registered: Aug-06 | Well, Jan is much more experienced and knowledgeable on the subject than I am, so I hate to differ, but in this case I will. If all you want it for is a little rumble for movies and video games, you're not an audiophile, the price is right and your expectations aren't exceedingly high, than I say go for it. Here's a link to some user reviews. They seem generally happy with what they got for what they spent. http://reviews.pricegrabber.com/subwoofer-speakers/m/35140442/ |
Platinum Member Username: Jan_b_vigneDallas, TX Post Number: 11917 Registered: May-04 | . I doubt whatever I say will stop Seth anyway. It sounds like he has $79.99 (plus tax) burning a hole in his pocket. |
Silver Member Username: WattsssupBarrie, ON Canada Post Number: 170 Registered: Aug-06 | Well, we still love ya Jan...keep on sharing your opinions! |
Silver Member Username: Xfacta82Post Number: 116 Registered: Mar-07 | Is there a better sub for around 100 dollars that I should look into? |
Silver Member Username: WattsssupBarrie, ON Canada Post Number: 171 Registered: Aug-06 | There aren't many choices within your budget. Order this one today (free shipping), and be happy. http://www.amazon.com/gp/product/B0002KVQBA |
Gold Member Username: Arande2Rattle your ... Missouri Post Number: 2760 Registered: Dec-06 | My recommendation is to save a little more money and buy something off of eBay or something. If you have a relatively small room, that rumbler may be fine if all you want is a little bit of "boom boom." |
Silver Member Username: Xfacta82Post Number: 119 Registered: Mar-07 | So the polk is better than the sony even though the sony has more power in wattage? |
Silver Member Username: WattsssupBarrie, ON Canada Post Number: 172 Registered: Aug-06 | Don't worry about what Sony says their wattage is, I know it's hard to understand, but it doesn't mean a thing. Yes, the Polk is better. |
Platinum Member Username: Jan_b_vigneDallas, TX Post Number: 11926 Registered: May-04 | . Buy the Polk. |
Gold Member Username: ArtkAlbany, Oregon USA Post Number: 5841 Registered: Feb-05 | Buy the Polk Seth...hurry before they run out! |
Gold Member Username: NuckPost Number: 9527 Registered: Dec-04 | yep! |
Silver Member Username: DmitchellOttawa, Ontario Canada Post Number: 494 Registered: Feb-07 | Buy the Polk. I have 2. |
