Arcam CD62T vs CD72T
beatnic
Hi all,
What are the differences between Arcam CD62T and CD72T CD player, in term of sound quality. I know the CD62T is a "cut-down" version of its bigger brother, thus losing the ability to upgrade.. and the 62 uses smaller transformer instead of DC coupled one..
Please advice
Thx
Username: Tons_of_fun
LondonUK
Provided that you never intend to upgrade it (and few do) and you don't get excited over remotes (the 72's was better) I think the audio difference between the two was best descibed as bugger all.
beatnic
thx Ed..
I do get excited with the grey remote though :D
