Merry Christmas to me! I am having a nightmare with this new ipod nano!!! No help that the instructions are no help at all. Ok, so i have moved all my music into itunes music.... converted them to AAC format, but how the hec to i transfer tem onto my ipod??? Think i am about to throw it! Can anyone give me a few suggestions? Thanks a million...
Check the iTunes music library if all your music is in there.
Now connect the iPod. Under playlists, you should be able to see the iPod's icon under a name you've given it. If it is your first time setting up, just follow the prompts and make sure that you check "Manually manage music".
Once you've gone through all that, just drag and drop the music from your library to the iPod icon.
Do not, under any circumstances disconnect your iPod without ejecting it first from iTunes.
Thanks Berny. I ended up ringing Apple. Turns out that my new computer screen needed to be made smaller (the resolution!) so the "continue" button I was supposed to click on I couldn't see.... I felt sooo stupid. Thanks again.
Now I have another problem! Oh dear. I dont think i am supposed to have my toy!! Now all my songs are choppy, they sound all chopped up. What on earth have i done now?
