Gold Member Username: Nd4spd18Northwest PA Post Number: 4818 Registered: Jul-06 | Hey guys. I've been into car audio for a long time and post in those sections a lot, but I don't know as much about home audio. My home stereo is nothing special but good enough for me. 2 channel stereo Technics receiver/amplifier and a set of big 3way Technics speakers. I just got a subwoofer for free, and I'm looking for a 250+ watts at 4 ohm amplifier to power it. I'd like to keep it as cheap as possible, I don't need real high end equipment. Any amp suggestions? |
Gold Member Username: Naledge503Http://com4.runboard.c... Post Number: 2480 Registered: Jun-06 | I will try to help here. Dont know if you are looking for a plate amp or not but you could check these out. http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=300-805 http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=300-750 |
Platinum Member Username: WingmanaliveA pic is worth 1000 posts!! Post Number: 11926 Registered: Jun-06 | Connect the sub out line from your receiver and run it to something like this amp. $100 isn't bad. You know about boxes and such so try and tune lower than you would in your car. I'm happy with my 1000w dayton plate amp. http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=300-804 |
Platinum Member Username: WingmanaliveA pic is worth 1000 posts!! Post Number: 11927 Registered: Jun-06 | There you go lol. It doesn't have to be a plate amp but it's what I prefer. |
Gold Member Username: Naledge503Http://com4.runboard.c... Post Number: 2481 Registered: Jun-06 | lol....what is the difference between the amp in my first link and the one in your link? They have different part numbers but it looks like they are the same and they have the same price... |
Gold Member Username: Nd4spd18Northwest PA Post Number: 4826 Registered: Jul-06 | Thanks guys ![]() |
Platinum Member Username: WingmanaliveA pic is worth 1000 posts!! Post Number: 11929 Registered: Jun-06 | Jesse, one has bass boost the other doesn't. |
Gold Member Username: Nd4spd18Northwest PA Post Number: 4865 Registered: Jul-06 | Thanks guys. I ordered the one Paul recommended. |
