Bronze Member Username: LamcamStanton, Ca Usa Post Number: 17 Registered: Nov-07 | Should I connect the digital out (optical) from the DVD player to the receiver for music and movies or using the RCA output for music? Thanks. |
Silver Member Username: EramseySouth carolina United States Post Number: 572 Registered: Feb-05 | Loc: Try both. Use the connection that sounds best to you. |
Silver Member Username: Nickelbut10Post Number: 891 Registered: Jun-07 | Loc Ho-depends on which unit has the best DAC's. If the DVD player has the better DAC's then it will sound better through RCA. If the Receiver has the better DAC's of the two, then it will sound better through a digital connection. Try both though, and your ears will be the judge. |
Bronze Member Username: LamcamStanton, Ca Usa Post Number: 18 Registered: Nov-07 | Thanks! I will try both. |
Gold Member Username: Frank_abelaBerkshire UK Post Number: 2604 Registered: Sep-04 | Do not be surprised if the music is a bit more engaging when played via the analogue connection. The main problem with the S/PDIF or Toslink connections is with the actual connecitons themselves which introduce jitter, a form of digital distortion. Since the internal DAC of the DVD player doesn't have this buffer, it should theoretically have less jitter, although this is dependant on implementation. Regards, Frank. |
Silver Member Username: EramseySouth carolina United States Post Number: 573 Registered: Feb-05 | Frank makes an interesting point. After reading this http://www.stereophile.com/reference/1093jitter/index2.html there is some evidince,although scant little empiricle, that both the SPDIF(Sony-Phillips) and the Toslink optical(Toshiba) are problematic interfaces in amoung themselves,clock induced jitter(error) aside. Both are a multiplexed signal. The problem is one of propigation. Running a complex multiple bitsream signal through a single conductor without compression-(undesirable for 44.1KHz) can and will induce an ocassional error. This is why Apple Firewire and HDMI are superior to Toslink and SPDIF because the individual signals of the bitstream are given their own independent conductor so the signal is remarkably pure and uncorrupt and still has the same benefit of signal comparison. IF the OP wants surround sound primarily then he sould go with the digital connection without question. |
Silver Member Username: GeekboyTampa, FL United States Post Number: 450 Registered: Dec-03 | Translating for Eric: you might want to just use the analogue connections. ![]() For stereo listening, I always use the DACS in my CD/DVD player. They are the same as or better than the DACs in my receiver. |
Gold Member Username: NuckPost Number: 9535 Registered: Dec-04 | I run(ran) the SP/DIF of my puter soundcard to the DAC with tremendous results. |
