KENWOOD Question
Username: Me_me
Post Number: 71
i have a kenwood (KR-897) 5 STERIO SYSTEM WAS LISTNING TO THE RADIO HERAD A POP ON BIG SPEAKER.
AND NOW I CAN'T GET SOUND ON MY SPERAKERS.
CAN SOMEONE TELL ME WHATS WRONG.
THANKS
Username: Dmitchell
Ottawa, Ontario Canada
Post Number: 473
You can't get sounds out of any of the speakers?
Sounds like the receiver is toast.
Username: Nuck
Post Number: 9460
sure. First you must be deaf because you are YELLING.
Next, you need to follow basic troubleshooting procedures, like swapping one speaker at a time, to see if you have sound from just one channel.
Stereo is spelled like this, S t e r e o
Username: Dmitchell
Post Number: 474
Thanks Nuck, I really had to restrain myself.
Username: Me_me
Post Number: 72
i can hear the surround sound static but my big speaker i can't hear anything.and when i put on tuner or cd it use to say tuner station or cd but now it say sterio or differen't seting of sound. what i can i do, can i fix it
thanks for your help.
Username: Dmitchell
Post Number: 475
Can you fix it? Not likely.
Could an electronics technician fix it? Most likely.
Is it worth it? Not likely.
Username: Nuck
Post Number: 9461
How about in 2 channel, with just one speaker connected?
