Automatic turntable won't stop spinning
Username: Robertzombie
LondonEngland
I have a Sony PS-lX4. It's an automatic turntable so obviously once the record has finished the arm returns to it's starting position and the turntable slows to a halt.
For some reason the other day, the record had finished, the arm had returned to the side but the turntable continued spinning and wouldn't stop (so I had to turn it off the plug).
I powered it back up a while later and the turntable started spinning again even though the arm was in the start position.
So basically the thing will carry on spinning until I unplug the record player.
Does anyone know what's gone wrong and how I can fix it? It still plays records but there's obviously something wrong with it otherwise it would stop spinning.
Any help would be much appreciated =)
Username: Jan_b_vigne
Dallas, TX
Post Number: 11819
How you can fix it? You mean like tell you what part has slipped a cog and how to get it back in place? Or do you mean tell you what repair shop to take it to so they can fix it for you?
Username: Mike3
Wylie, Tx USA
Post Number: 912
Let it spin, it won't hurt it.
