Silver Member Username: Pbplayer05Carroll, Iowa Post Number: 139 Registered: May-07 | just a quick question not to sure about home theater but i dont have much to spend i was thinking about a 500 wat plate amp but wat are some good ht subs and speaker that dont cost to much maybe a reciever and a cd player also info would help thanks |
Silver Member Username: DmitchellOttawa, Ontario Canada Post Number: 428 Registered: Feb-07 | Andre should be along shortly... |
Gold Member Username: NuckPost Number: 9378 Registered: Dec-04 | Hsu and SVS make affordable subs without the sawdust and wiring a plate amp. jl, if you don't have tools and a lot of research, just buy one. |
Silver Member Username: Pbplayer05Carroll, Iowa Post Number: 140 Registered: May-07 | were do you find those at |
Silver Member Username: DmitchellOttawa, Ontario Canada Post Number: 432 Registered: Feb-07 | Online. http://www.hsuresearch.com/ http://www.svsound.com/index.cfm |
Silver Member Username: Pbplayer05Carroll, Iowa Post Number: 142 Registered: May-07 | no crap there online dump a55 also those are not very cheap as i stated i dont have much to spend |
Gold Member Username: NuckPost Number: 9382 Registered: Dec-04 | then you won't get much in return. |
Silver Member Username: Nickelbut10Post Number: 833 Registered: Jun-07 | HSU I know has subs for under 500. |
