Help!!!... Buzz coming from turntable listening at higher volume
Username: Narkota
RigaLatvia
Hi everyone,
May be some of you can help me to fix the problem. I recently bought a Pro-Ject DebutIII/Phono SB turntable with already built-in phono preamp and speedbox. Everything works fine while listening at volume level 5-6 out of 10. When I am starting to turn volume louder the speakers starting to buzz and this is very annoying.
May be this can help: As the turntable already have built-in phono preamp I have connected it straight to receiver. Ough .. together with phono plugs which come out from turntabale's phono box there is a ground wire which is not connected because there is no possibilities to connect ground wire to receiver and I left it hanging. Can this be a reason for buzzing???
Username: Nuck
Post Number: 9267
GK, if the ground was an issue, I think you would have noise issues at all output levels.
Sounds like microphonics to me.
Have a look at the placement of your table. Is it exposed to the sound waves in the room directly?
How is the table supported?
Username: Artk
Albany, Oregon USA
Post Number: 5666
You need to connect the ground wire...use a screw on the receiver as long as it connects the ground wire to the metal case of the receiver. Or you can use a screw on the rack...whatever just connect the ground and see where you stand.
Username: Stu_pitt
Irvington, New York USA
Post Number: 2288
"...there is a ground wire which is not connected because there is no possibilities to connect ground wire to receiver and I left it hanging. Can this be a reason for buzzing???"
This is the exact reason why. Turntables need to be grounded. The RCAs and power plug won't do it.
Loosen a screw on the back of the chasis of your receiver, attach the ground wire, then tighten it back up.
Nuck's advice also helps, but that's not the real issue here.
Username: Narkota
RigaLatvia
Nuck,I have placed my turntable just on the simple wooden table. On previous message I forgot to tell, that the buzzing on higher volume level appears even vinyl is not rotating and tonearm sit on its place.
Username: Stu_pitt
Post Number: 2289
Posts crossed Art.
Username: Narkota
RigaLatvia
Thaks Stu, I will definatelly try your suggestion, but one more question - Is it safe? I mean if there's no special places to connect ground wire to receiver won't this can do any short circuit???
Username: Nuck
Post Number: 9270
OK, so now we get to the real issue.
Just like the guys say, use the ground.
Yes it is safe.
Alternatively, you can ground the wire to the screw that holds the cover plate of the wall recepticle in place.
Username: Nuck
Post Number: 9271
You can also make a 'lasso' on the ground and loop it around the rca of the receiver, then plant it with the rca push in.
Username: Narkota
RigaLatvia
Thanks!
Will try one of those issues. Hope that will help.
