Sub Connections??? Help??? Help??????
jon k
I owned VSX-811S with Bose Acous. 15 system and with Bose 161 for my Rear Centers. I am very satisfied with my current system except that I need more Bass. I was thinking about adding a JBL 12" Powered Sub additional to my Bose.
But the question is: Can I use a seperate Sub to work on my system? The Bose connections goes from the Receiver to the Bose Sub and then to the Speakers. How can I hook up another Sub? I was thinking about the RCA "Sub Out" connection in back of my Receiver. But I do not know if this will work. Does anybody have any ideas???
Any help would be appreciated.
THE SUB OUT WILL WORK.....YOUR SUB TO BUY IS SELF AMPLIFIED...ALSO IF YOU HAVE A SECOND SET OF MAIN OR FRONT SPEAKER OUTPUTS, YOU CAN UTULIZE THEM AS WELL.A SELF AMPLIFIES SUB WILL WORK WITH ANY PRE-OUT OR OUTPUT WITH MUSICAL INFORMATION COMING OUT OF THEM.THE SUB OUT IS FOR LOW FREQUENCIES SO USE IT.
jon k
Thanks for you advice.
