Universal remote control for rega mira3
Username: Mirod
What universal RC works with this amp.
Thank for your replay.
Mirod
Username: Jan_b_vigne
Dallas, TX
Post Number: 11728
Try a learning remote.
Username: Mirod
Could you recommend any rearning rc?
I tied some learning rc, but they didn't
work correctly.(switching inputs did't work)
ps:i haven't original rega solar.
Dallas, TX
Post Number: 11733
No, I can't. It is unusual to find any remote than accepts all codes. You might try calling the Rega distributor. Ask which remote their's is based on. Most remotes for companies such as Rega are not proprietary to Rega but are taken from other companies and Rega tacks on their own codes for particular functions. But you may not be able to have all codes in one universal. That's just kinda life in the land of universal remotes.
Username: Nuck
Post Number: 9202
And there will always, always be a function that does not work.
Username: Artk
Albany, Oregon USA
Post Number: 5619
So buy a Solar...problem solved.
Username: Frank_abela
Berkshire UK
Post Number: 2516
If you look on Rega's site you'll find the Solar remote manual (under Products, then Accessories)which contains all the codes, so youshould eb able to program them into your learning remote.
The Solar remote speaks RC5 which is just about the most common language for remote controls. Any learning remote, such as a Pronto should be able to handle this.
Regards,
Frank.
Username: Mirod
Thanks all.
I"ll try Pronto.
MiroD
Berkshire UK
Post Number: 2523
Miro
The pronto was just an example! I know nothing about learning remotes.
Regards,
Frank.
Username: Davidpa
Portland, Oregon US
Post Number: 495
The pronto JFYI, can be a pain. I have a Mosaic, and it carried more codes for my system, and was a bit easier to have it learn the functions it did not know.
I tried the Pronto on two seperate occasions, the last being last xmas (my wife bought it for me) cant remember model number, but it was a 2000.00 remote at the time, color screen etc. and even through their website there were certain functions, as well as my Rotel DVD player that it would not accomodate.
Maybe things have changed by now, but for me, it was just easier to stick with the Mosaic.
Username: Magfan
Post Number: 51
Can you get some help from the Logitech/Harmony folks?
