hey guys, im really new to this, just moved in to new house. Just purchased an amp and the house has 4 insulated speakers, Having trouble distinguishing between negative and positive. Theres a silver cable and a copper cable for each speaker, which is which?
thanks guys, and once again, this has probably been covered many times but Im brand new to this. Thank u
You get to decide. As long as you're consistent from speaker to speaker they will all be in phase if they are connected consistently at the speakers. If you wish to check for correct phase, touch the ends of each speaker cable (one speaker at a time) to the + and - terminals of a small battery. All the speakers should move forward when the positive leg of the cable is on the positive terminal of the battery. If one draws backward, mark that speaker as out of phase.
