Speaker recommedations for Cambridge Audio
Username: Andrewh973
Post Number: 7
Hello All,
After auditioning a few different components, I'm finally leaning toward the Cambridge Audio Azur integrated amp and corresponding CD player.
Are there any recommendations for compatible speakers for these units? Bookshelf size, preferable, due to lack of floor space. I listen to all genres, low to moderate levels--with the occassional blast. $500 - $700 range.
Thanks in advance.
Username: Nuck
Post Number: 9105
Hi Andrew.
Are you actually looking to place the speakers in a bookshelf?
Not the usual scene, stands are more likely, but hey, ya gotta do what ya gotta do.
I like the PSB B25 speakers.
But they ain't small.
You could look into Mini Monitors from Paradigm as well.
NHT make some strong little speakers, but the bass response is limited from the ones I have heard.More input from NHT guys?
Post Number: 8
Thanks for your response, Nuck. No, the speakers won't go into a bookshelf, but most likely on top of a long wooden cabinet with the components in the middle. Nothing above the cabinet. How are the PSB B25 speakers? And would they be compatible with the Cambridge Audio pieces?
Username: Exerciseguy
Fort Hamilton, NY United States
Post Number: 1461
Three sub $500 contenders, IMHO:
Monitor Audio Silver S2 for $465 w/FREE s/h http://av123.wetpaint.com/page/x-ls+Super+Wave+Guide+%28swg%29
I had an Azur 540A & 540D combo, so I'm kind of familiar with the sound.
Post Number: 1462
I should also add the Wharfedale Diamond 9.2 to this group for $292 + s/h http://ayselectronics.com/index.php?main_page=product_info&products_id=5150&zeni d=f3ab745424c2ccbfc327346f7681f355
Post Number: 1463
I wouldn't call any of my above recommendations small either.
Any of the Azur integrated amps will drive these speakers well, and I'm fairly certain you would not go wrong with any of the above.
But I've got to tell you that I'm not a fan of the current Paradigm Monitor Series, but they are certainly worth a listen, you may like them.
Username: Nickelbut10
Post Number: 680
The Atoms are pretty good, but from what I hear the Monitor Audio bookies are a great mix with Cambridge Products.
Post Number: 1464
Correction: The above Monitor Audio recommendation should read the Silver RS1, not S2 which are now discontinued. Sorry.
Post Number: 9
Thanks Christopher. I've heard a lot about the Monitor Audio RS1, but have not yet auditioned them. I'll find a dealer in the area, and will definitely go for a listen. What's their approximate cost? And what kind of cables are recommended?
Post Number: 1465
The cost for the RS1 is in the above link, $465.
I'm not a fan of fancy cables. I use these http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=181-600 and am pretty happy.
Post Number: 1466
...I should say I'm not a fan of expensive fancy cables.
Ain't nothing wrong with frugal fancy cables.
...hmmm? Frugal Fancy Cables, LLC...interesting?
