Sony STRDG500 help needed
Username: Poochi425
Mis, On
Post Number: 21
Hi All
I bought the sony rcvr recently and worked fine for a week or two but then all of a sudden the recvr. fails to emit any sound from the sub.
I even tried going thru the test-tone menu but all the other spkrs pass the test tone test but nothing comes out of the subwoofer. dunno why ?
what caused it ?
may be the settings ? i went thru the manual, tried every possible setting but no result...
Took it to the sony service depot, they were not helpful at all instead had a big yellow sticky posted on the box saying: please follow the instructions in the manual, no fault found but won't specify what settings to use or what may have caused the subwoofer to go quite.
i would really appreciate everybody's input on this.
p.s. i'm using regular rca audio cables for connections.
thx
Username: Nuck
Post Number: 9039
pooch, did you try speaker level connection? Is this available on your sub?
Username: Poochi425
Mis, On
Post Number: 23
no its a passive sub that came with the sony hometheater in a box.
i plugged it in with my new rcvr.
is it possible that when i tried the other audio connection i.e. coaxial-in
it may have turned-off the sub... i dunno
yr help is appreciated
