New member Username: ParnellyPost Number: 1 Registered: Oct-07 | Okay here's the deal, Im looking for parts for this bad boy. What i need is new rca jacks all across the board. I need 24 to fix the front channels and i need 20 to fix the rear channels. The different number is due to the phono's being used for front and rear for some reason. If any one knows where i can get jacks that will mount up to my bose 4401 pre amp please fill me in. I thank you in advance for anyone who has any info on such a thing. |
Gold Member Username: NuckPost Number: 9028 Registered: Dec-04 | Ben does this BAD thing use regular rca connections? Like the cables and rca jacks available from partsexpress.com in 50 lots? |
New member Username: ParnellyPost Number: 2 Registered: Oct-07 | k sorry to have bothered anybody. I dug further into this and have found what i need so for any one out there with a 4401 pre amp. This is what you need Straight PCB(Printed Circuit Board) mounted pin jacks. I have found a website www.toby.co.uk which sells these. |
