The Music
Username: Arande2
Rattle your ... Missouri
Post Number: 2630
What would Dark Side of the Moon sound like on a Continuum Audio Labs Caliburn turntable & Cobra tonearm, a 150w/channel SET Amp (forgot name), the shortest, best cables possible, the best phono preamp, the best room acoustics, custom-built speakers rated completely flat in that room with the person in it 15hz-30khz, and a specially designed line conditioner VARIAC for each separate component for best performance ---- compared to a standard high-end CD Player (maybe $1000) with custom-molded earphones and a Headroom MAX headphone amp?
So pretty much...$1.5m LP/Speaker-Based system compared to a $4000 CD/Headphone-Based system.
I found I had a friend that collects a bunch of records and has a lot of my favorite songs on vinyl.
Well... I really don't know what it would sound like comparatively.
Username: Wattsssup
Barrie, ON Canada
Post Number: 111
That album will sound amazing even if you play it through a cell phone.
Username: Arande2
Post Number: 2631
Ha
Username: Wildman10387
Holden, Massachusetts
Post Number: 20
it sounds good anytime.
