New member Username: Mikerod007Post Number: 5 Registered: Oct-07 | I apologize for this simple question. Since this HK is a stereo receiver, I thought there would be two connections for speakers. However, when I look at the back, I see four. Can someone explain this to me? Thanks |
New member Username: NowayPost Number: 4 Registered: Oct-07 | From the owners manual: "Connect the front left and right loudspeakers to the Speaker 1 speaker terminals on the HK 3485. Remember to maintain the proper polarity by always connecting the positive and negative terminals on each speaker to the positive and negative terminals on the receiver. If you wish to place a second pair of speakers in another room, or in the same room for additional sound power, connect those speakers to the Speaker 2 Outputs, again remembering to maintain polarity. You may use the Speaker 1/2 Selector on the front panel or remote to activate either or both pairs of speakers simultaneously." You can copy and paste the link below into your browser's address bar if you want the manual: http://manuals.harman.com/HK/Owner's%20Manual/HK%203485%20OM.pdf |
Silver Member Username: ShawnharmanPost Number: 149 Registered: Dec-05 | so in simple terms you hook up four speakers and they go boom boom. |
Gold Member Username: NuckPost Number: 8995 Registered: Dec-04 | If you are running 4 speakers, you want to use 8ohm, easy to drive ones. Elsen y'all might get just one boom. |
Silver Member Username: GamerdudeOntario Canada Post Number: 537 Registered: Apr-06 | Nuck it would depend on how the amp is built. the amp could either see it as 4 ohms on each channle (a,b) or it could see it as 16 ohms |
Gold Member Username: NuckPost Number: 9053 Registered: Dec-04 | Kyle, I am not aware of any A+B outputs in series. |
Platinum Member Username: Jan_b_vigneDallas, TX Post Number: 11644 Registered: May-04 | . Original Sony receivers from the 1960-70's and a few Kenwoods from the same period. Otherwise, not so much! |
Silver Member Username: GamerdudeOntario Canada Post Number: 538 Registered: Apr-06 | Either am I , I was told this info by my father |
Gold Member Username: NuckPost Number: 9057 Registered: Dec-04 | Dad was right. |
