Ipod Nano wont connect with Itunes, just charge.
Username: Supp_brittany
I just recently found an ipod nano and when I tried to upload my music onto it, it will only charge, it wont connect with itunes. I've tried the 5 R's or whatever, everything Apple suggests to try, but nothing works. Anyone know what to do?}
Username: Project6
Post Number: 14118
Try using a different USB cable.
When you say you "found an iPod Nano"...did you mean it was not yours and you just found it somewhere? If you did, there is probably a good reason why it was lost or thrown out.
Need to Register?
Forgot Password?
Enable HTML code in message
