Speaker Repair
Username: Dscrobe
Reading, PA USA
Post Number: 44
I accidentally ripped a vintage 8" 8 ohm loudspeaker. The diaphragm is made out of a black paper material. The rip is 1" in length and about an 1" away from the suspension. I recall reading about a fix for this and it doesn't involve scotch tape. Is there some kind of epoxy you have to use? How do I fix?
Username: Jan_b_vigne
Dallas, TX
Post Number: 11396
Use rubber cement.
Carefully.
Or go to a pro sound shop and ask for what they use.
Username: Nuck
Post Number: 8826
I have used nail polish successfully.
Dallas, TX
Post Number: 11398
For what?
A pic is worth 1000 posts!!
Post Number: 10367
You left the barn door wiiiide open for that one Nuck lol.
Username: Dscrobe
Reading, PA USA
Post Number: 46
Nuck, is it just a matter of brushing it on to form a layer over the rip?
Post Number: 10378
Silicon works as well.
Username: Mike3
Wylie, Tx USA
Post Number: 756
you can see Nuck's nail polish in the post by Stu of Nuck on "System Pics"
The one where he is carting around his virtual system on his shoulder
Username: Dscrobe
Reading, PA USA
Post Number: 47
Michael, had a difficult time finding that. I also heard that acrylic caulk would work as well. However, caulk is not easy to apply.
Username: Mike3
Wylie, Tx USA
Post Number: 768
Just a thought, and let me preface this by saying I never had to repair a speaker, but;
Would the patch, rubber cement, nail polish, whatever work better if daniel removed the speaker from the enclosure and applied the substance to back and front of the tear?
The speaker moves in and out so I am thinking it might rip again quicker if only one surface side was addressed.
Comments?
Dallas, TX
Post Number: 11488
Yes, it would. As long as he doesn't damage something else trying to get the driver out of the cabinet. Quite a few manufacturers have become exhausted by users who wish to DIY. For the sake of less warranty repairs due to stupidity and a better seal around the driver basket they make certain removing the driver is not very easy.
