Gold Member Username: Arande2Rattle your ... Missouri Post Number: 2610 Registered: Dec-06 | I have recently purchased a Pioneer Elite Vsx-91txh and it certainly demonstrates much improved sound quality at all levels compared to the old receiver. That is, of course, why I purchased it. The problem is that the bass has no power to it at any level. This is a problem of the speakers, and so I must augment them with a subwoofer. I recently changed the audio output on my computer from analog to digital as I decided the DACs in my receiver would be superior to those in the computer. They are. I have made sure all audio files on my computer are at least 256kb/s. This has improved it, but there's something wrong. Help. |
Silver Member Username: DmitchellOttawa, Ontario Canada Post Number: 326 Registered: Feb-07 | I'm not sure that the relatively poor quality of your audio sources would be responsible for the lack of bass... |
Gold Member Username: Arande2Rattle your ... Missouri Post Number: 2611 Registered: Dec-06 | I never said that. That's totally due to the speakers. |
Silver Member Username: DmitchellOttawa, Ontario Canada Post Number: 327 Registered: Feb-07 | What are the speakers? |
Gold Member Username: Arande2Rattle your ... Missouri Post Number: 2612 Registered: Dec-06 | KLH AV5001 x2 - Drivers: 1", 3" 12" PR: 12" (same excursion) - In-room usable output (tested by me) 45hz to as high as I can hear - measured 110dB 45hz and 100dB 37hz Used as mains JBL 4311 x2 - Drivers :N/A, N/A, 12" - In-room usable output 30hz on up - hit amplifier limits 113dB 40hz and 103dB 27hz Used as surrounds I'm going to try putting the JBL in the front due to the measurements. |
Platinum Member Username: WingmanaliveA pic is worth 1000 posts!! Post Number: 10330 Registered: Jun-06 | I have KLH speaks in my surrounds. They're old but work.![]() |
Gold Member Username: StefanomVienna, VA United States Post Number: 1008 Registered: Apr-06 | Get a subwoofer. Get a subwoofer that can get the SPLs that you're looking for. SVS probably would be a good one for you Andre. Or you can get one of my machinations. |
Gold Member Username: Arande2Rattle your ... Missouri Post Number: 2613 Registered: Dec-06 | http://www.avsforum.com/avs-vb/showthread.php?t=901241 It would've been built over a month ago if I had the cash. |
Gold Member Username: StefanomVienna, VA United States Post Number: 1010 Registered: Apr-06 | That is nothing compared to the awesome power of 144 2.5" drivers working in unison in a sealed enclosure. |
Gold Member Username: Arande2Rattle your ... Missouri Post Number: 2614 Registered: Dec-06 | Ok I decided to do the math because I'm bored. ![]() The one I designed has 650 cubic inches of displacement in the drivers. The one you're joking around about has 106 cubic inches, providing my math is correct. That's funny that those 2.5" drivers could have that much displacement. ![]() |
