Another use for my T-Amp
Username: Dmitchell
Ottawa, Ontario Canada
Post Number: 314
I was a little hesitant to try this since I didn't think my Trends TA-10.1 wouldn't go loud enough, but last night I used it to power my outdoor speakers on my deck.
Not only did it have more than enough volume, it sounded GOOD. Better than the 50 watt NAD I was using before.
Username: Nuck
Post Number: 8762
The little wonders never cease to amaze!
Username: Dmitchell
Post Number: 322
I have the T-Amp turned up maybe a quarter turn and it's plenty loud. It also sounds really, really good, even through some extraordinarily unremarkable Polk outdoor speakers.
Username: Nuck
Post Number: 8779
Is that a Trends or other uprated amp, Dave?
Username: Exerciseguy
Brooklyn, NY United States
Post Number: 1339
Yes, the Trends TA-10.1 is that good.
Best $100 I've spent in quite a while (I bought it used).
David, what speakers are you usually using with the Trends?
Username: Dmitchell
Post Number: 323
You're right Christopher, It's the TA-10.1. I tried it before awhile with my Tannoys and I found it didn't go loud enough (this was in my home gym - big room, concrete floor...). Strangely enough, outside, it sounds amazing. I'm hearing sh!t in familiar music that I haven't heard before.
