How can I power a 13w7 in my room? :-)
Username: Goldtooth
So far I have found only a possible amp.
Velodyne SC1250 but I think it runs on 4 ohm for single sub and 8 ohm for 2 subs. The 13w7 is dual 1.5ohm. Any ideas or suggestions? FYI, I know this is not the car audio section. All I'm looking for is some help finding an amp to power this beast. Thanks
Username: Shawnharman
Post Number: 121
your going to need to put a car amp in there with it my man, you will be spending ALOT of money if you want a home amp to be able to handle powering that thing.
Username: Goldtooth
I have a 1000/1, but its the wrong kind of power obviously for home use....
yea that SC1250 is like a grand...lol
Username: Allstar71
Jefferson, Ga
Post Number: 51
Not sure how much current your amp pulls...but this can produce 80 amps @ 13.8v...
http://www.sportsimportsltd.com/80ampfurelow.html
Username: Goldtooth
hmmm, but what ohm-age does that amp support though? My car amp is 1000watt continous
Username: Allstar71
Jefferson, Ga
Post Number: 52
this is not an amp...it is a power supply to power your car amp...it gives you dc power (car battery) from an ac source (wall plug in)...
Username: Goldtooth
whoops, i didnt even notice, probably cuz I had to leave in less than 5 min while finishing up some homework....
so now I would have to figure out how much MAX amps my amp needs?
Username: Allstar71
Jefferson, Ga
Post Number: 53
yeah, there are a variety of these dc power supplies. So look for the one that is best for your amp. I thought 80 amps would be close. I think that the calculation is watts/voltage = amps
if this is the case it will need approx. 83-84 amps max. If this is the case this supply would work.
Username: Goldtooth
thanks man! I will look around
