New member Username: TdubSaskatoon, Sask. Canada Post Number: 4 Registered: Nov-04 | I have a new Ortofon omb 5e and i also found a new shure N97HE stylus for my old M97 cartridge. My question is that I would like to compare the two on my Dual 510 tt. Is there any advice on the cartridge installation on the 510? Thanx |
Platinum Member Username: Jan_b_vigneDallas, TX Post Number: 11343 Registered: May-04 | . Do you have an alignment guage for the Dual? |
New member Username: TdubSaskatoon, Sask. Canada Post Number: 6 Registered: Nov-04 | No I do not. I have one of those mirrored alignment devices that sits on the platter. |
Platinum Member Username: Jan_b_vigneDallas, TX Post Number: 11347 Registered: May-04 | . Those are a pain to use with the Dual but you can do it. So, what's the question? You install the cartridge and balance the tonearm. |
New member Username: TdubSaskatoon, Sask. Canada Post Number: 7 Registered: Nov-04 | I should have been clear on my concerns. I was reading a manual on cartridge installation for Dual tt's. It indicated that the cartidges should be equipped with Dual mounting supports which automatically have the accutate geometric position in regard to the stylus. I just do not want to mess up. Just looking for insight. Thanx |
Platinum Member Username: Jan_b_vigneDallas, TX Post Number: 11351 Registered: May-04 | . I'm not certain what you might have been reading. Possibly something regarding the old "P" mount cartidges. http://www.dual-reference.com/index.html |
Gold Member Username: NuckPost Number: 8744 Registered: Dec-04 | Hi Tim. Jan has serviced more tt's than I can spell. If you get right in depth, you will have help. I can't help you, but I will follow along. |
New member Username: TdubSaskatoon, Sask. Canada Post Number: 8 Registered: Nov-04 | The info I found is also in the Dual 510 instruction manual that I finally dug up. The old cartridge Off the 510 is a shure M95ED HI-TRACK. It has a spacer between the cart and the headshell. But when I line the hi track up beside the m97 and the ortofon they are deeper than the hi track. I am just going to install them on my 2 headshells without spacers line them up and see what happens. I will keep you posted on my results. Thanx for your interest. Tim |
New member Username: TdubSaskatoon, Sask. Canada Post Number: 9 Registered: Nov-04 | The Shure M97 lines up nice on with the mirrored device. The Ortofon is giving me trouble because of the shape. Have not completed a proper alignment yet. The M97 is a sonic improvment over the original high track. |
