There are many advantages and disadvantages to both large and small drivers. Too many to list here, but you should forget the idea that size indicates "speed". This is an enduring fabrication that is completely without foundation in today's warket. Buy what sounds best.
Cheers, I wont worry about it too much. Although i did wonder to myself about the market creating the 'enduring fabrication'.
I shall find out for myself wont I.
Jan, I do have a question for you specifically-do you 'believe' in standing waves. In the audio advantage of curved cabinets or do you consider this at all an enduring marketing fabrication. Just curious on what you think.
Well, probably you won't actually find out. The relative speed of a driver is the result of several factors, most of which are not published for assembled speaker systems. Mere position in the room can give the effect of a faster driver. How the enclosure is supported can do likewise.
Here's one thing you can count on. If the two differently sized drivers are operating up to the same crossover frequency, the smaller driver will have the more consistent and evenly distributed dispersion. As the wavelength of the reproduced frequency becomes smaller than the cross section of the driver, the driver begins to radiate in a more directional pattern. So your new 6.8" driver may sound a bit more directional in the midrange and might require more accurate placement. You can use this to your advantage or disadvantage. Of course, everything changes if the filters are at dissimilar frequencies and/or the slope is not similar to your old speakers.
Certainly I believe in standing waves inside a cabinet. But a speaker designer would have to be very sloppy to allow such problems. And, in the whole scheme of things, there are far more important matters to consider.
This is one of the main reasons I've reserved some Wharfedale Evolution 2-10 speakers, because I believed so much in the standing waves theory. They're usually £360 but managing to get them for £200.
Thanks for that Jan, but theres two things which do confuse me. If standing waves are infact a matter, why do so many companies-being the majority have square cabinets!! Of course the evolution 2-10s do have upgraded technology which I read about in the pdf manual.
But as you said, room placement is very much key as I've found out.
If the midrange has more directional placement, wouldnt that mean imaging would be more precise! I'd use this as an advantage here.
I haven't commited to buying the speakers yet, but I have been thinking whether or not to cancel the order. What do you think?
p.s. Specifically reserved the evo 2-10 and not the evo 2-8s because I've had to put a high shelf minus 3db gain on upper frequncies (set to my speaker crossover of 2200hz) on my current diamond 8.1s. In other words there's basically too much treble for the speakers.
pps and a -5db drop at 100hz.
ppps Nowhere has the evos for demo and I go to uni in 2 weeks.
Why would you assume directionality would benefit imaging? A basic problem with any multidriver speaker is the discontinuity between the increasing directional upper frequencies produced by the larger driver and the wide dispersion of the smaller driver (tweeter) which will be reproducing those same frequencies throughout the crossover region. This area of dicontinuity in timbre and dispersion is a failing point for many speakers and a major reason for the existence of single driver designs be they dynamic driver or panel based systems. Certainly the coherence of a decent single driver can create more accurate imaging than most multidriver systems can manage.
In theory, Jan is correct.In practice however, some multidriver units do outperform some single driver units. It all depends on how the theory is applied to construction.
Neither is wiley who will soon chime in that you are his new best friend as he has run off every other new best friend he has cozied up to on this forum and, therefore, has no friends on this forum.
I neither have nor seek friends through this forum.To do so would be shallow and the kind of thing that Vigne customarily does. He has quite a number of sycophants here.For me, if you're right, you're right. And when you're wrong, you're wrong. When Vigne is right, I acknowledge it. When he is wrong, I call him on it. It's that simple. Unfortunately, he can't stand to be told he is wrong-the sign of a petty mind.
They probably kicked him out when he tried sticking slugs in the machine and striking up a conversation with a five year old. Of course, sniffing the "April Fresh" fabric softener while it was still in the dispenser didn't help his cause. Poor wiley, he don't know right or wrong. That's one reason he's almost always wrong. The other - he's an idiot.
He got this one right by luck, "Jan is correct."
You can go now, wiley. The dog catcher's coming for you.
"Or, if it's easier, just tell us about your gigantic Radio Shack speakers in your single wide mobile trailer. How's your Mom feel about having to push her walker and oxygen tanks around those suckers? Bet she yells at you, huh?" Jan Vigne
"You're very sensitive about abusing your Mother; aren't you, wiley?" Jan Vigne
