Matching bookshelfs for NAD
Username: Andrewh973
Hi,
Can I get some recommendations for bookshelf speakers to be matched to NAD C542 CD Player and NAD C325BEE Intergrated amp.
Dues to smaller living room and configuration, bookshelf speakers are in order. Music listened to: rock, jazz, classical, folk, vocals.
Much appreciated.
Andrew
Username: Stu_pitt
Irvington, New York USA
Post Number: 2090
My personal favorite is the PSB Image B25. Its really the speaker to beat in its price range IMO. Great speaker and great synergy with NAD.
Paradigm, B&W, Epos, and Energy all make very good speakers for about the same budget range. The best is a personal thing.
Username: Jan_b_vigne
Dallas, TX
Post Number: 11270
Do they really have to fit on a bookshelf? Can you use stands?
Stu, thanks much for the advice. Jan, stands are possible, but the living room is configured such that it'll be difficult--they'll be in the way. What did you have in mind?
Username: Exerciseguy
Brooklyn, NY United States
Post Number: 1297
Budget?
Post Number: 1298
Are speakers ever actually put on bookshelves? Wall-units perhaps, but bookshelves, now that's a rarity.
Username: Malco49
Baltimore, Maryland Usa
Post Number: 121
i would have to concur that bookshelf speakers rarely fit on bookshelves! many mini system speakers but not stand alone speakers.
i champion the PSB image B25's that i use with my cambridge AZUR 540A(v1)not that different at least in price from NAD.
can't say i have heard tons of bookshelves but when i went to buy speakers i heard KEF and Focal and once i heard the PSB's was sold right away.
now i do use mine on atlantis speakerstands and isonode isolation.i find the speakers dynamic and able to handle a wide range of music stlyes.
good luck with your choice.
Post Number: 1299
http://cgi.ebay.com/PSB-IMAGE-B25-BOOKSHELF-SPEAKERS_W0QQitemZ300150566789QQcmdZ ViewItem
Post Number: 1300
I'm sure the PSB B25 are a fantastic match with the NAD (I've heard the B25 with a differrent NAD amp, and it sounded great from what I can rememeber), but if the budget is in the $500 range, I would also strongly consider a pair of Monitor Audio S2 http://www.saturdayaudio.com/ for $449+s/h, the S2 is a bit more detailed than the B25 IMHO, and would mate well with the warmth of the NAD.
The Wharfedale Diamond 9.2 for $292+s/h is another strong contender http://ayselectronics.com/index.php?main_page=product_info&products_id=5150&zeni d=9356d577213ed2c21ff6486c3e9fb4b3
And the Infinity Beta 20 for $248 (delivered) http://cgi.ebay.com/INFINITY-BETA-20-CHERRY-NEW-PAIR-199-AUTHORIZED-SELLER_W0QQi temZ130153091596QQihZ003QQcategoryZ14991QQcmdZViewItem
Username: Nuck
Post Number: 8636
Hey kids, like I said, CM can shop!
