Silver Member Username: Hoosier_daddyPost Number: 124 Registered: Dec-06 | looking for remote for Onkyo tx-sv919thx did not find any on ebay... Thoughts? |
Silver Member Username: ShawnharmanPost Number: 111 Registered: Dec-05 | http://www.partstore.com/Model/Onkyo+Corporation/Onkyo/TXSV919THX.aspx this might help. |
Silver Member Username: Nickelbut10Post Number: 392 Registered: Jun-07 | If you cant get one for the actual Onkyo, a Logitech universal or something of the sort should cover the basic functions at least. Mine covers everything. |
Platinum Member Username: Jan_b_vigneDallas, TX Post Number: 11260 Registered: May-04 | . Any Onkyo service center can order a factory replacement. Buying a pre-programmed universal will be much less expensive. Most universals do not cover all the functions the O.E.M. unit had. |
