Home stereo receiver w/built in equalizer
Username: Bobcat100913
Pa Usa
I am looking to replace a JVC RX750VK Compulink. It features a built in graphic equalizer as well as jacks for phono, cd, aux, tape 1, tape 2, video 1, video 2, and vcr. It was 100 wpc.
I am having no luck since most companies are selling home theatre units which I am not interested in. I am simply looking for a good stereo receiver with the above features. The Onkyo TX8522 has been recommended but it does not have the graphic equalizer.
If anyone has any knowledge on where I can purchase one it would be greatly appreciated. Thanx in advance
Username: Jan_b_vigne
Dallas, TX
Post Number: 11222
https://www.ecoustics.com/electronics/forum/home-audio/380776.html
Pa Usa
Sorry but none of that thread helped. I do not want a separate EQ. I want one that is already built into the receiver. Looks like I might be spending some cash to get the JVC fixed since I can't find what I want anywhere. Thanks anyway. If anyone else has any ideas I'm all ears.
Username: Nuck
Post Number: 8564
Bob, you will not like what I have to offer, so I won't.
Fix the JVC.
Username: Shawnharman
Post Number: 104
why do you feel you need a buit in EQ? a seperate one would do just as good, if not better. you wont find any new stuff with that, so you might want to look into used stuff. ebay as loads of jvc's with built in EQ's on there.
Post Number: 106
here is a few you could look at.
http://cgi.ebay.com/JVC-R-X40-DIGITAL-SYNTHESIZER-STEREO-RECEIVER-No-Res_W0QQite mZ150156959018QQihZ005QQcategoryZ3279QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
http://cgi.ebay.com/JVC-JR-5300-STEREO-RECEIVER_W0QQitemZ120158568183QQihZ002QQc ategoryZ3279QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
http://cgi.ebay.com/JVC-RX-302-FM-AM-Digital-Synthesizer-Receiver_W0QQitemZ26015 6123988QQihZ016QQcategoryZ3279QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
this one would be the one I would get if I were you
http://cgi.ebay.com/JVC-Stereo-Receiver-Amp-Amplifier-Tuner_W0QQitemZ14015483866 6QQihZ004QQcategoryZ3279QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Pa Usa
I checked all the above links and the only thing that had a listing was the 2nd one. All the others have been removed. The reason I wanted a built in EQ was that it was a really nice feature, and I really don't have any room to spare, besides, all of the new receivers I have looked at are not compatible with everything I want. Some of them don't have the same amount of hook-ups in the back that I need.
Post Number: 107
none of them have been removed, they all have at leat a day or so left on them, a stereo receiver you can look at is the harman kardon 3845 receiver, it should have everything you need. and it is a very good receiver, it will be a big upgrade from your jvc. but it dont have a built in EQ
Pa Usa
Wow I'm sorry, when I clicked on them now they all came up but when I did it earlier the 1st, 3rd and 4th came up "this item has been removed". Must be something with ebay.
Post Number: 108
its ok just trying to help, if you want a built in EQ I say go for the last one its cheap and will sound good, I think its the best out of all of them.
