Nope you Just need to Run the Optical Cable From the Reciver to which ever Device you want to use it for, When using the Device through the reciver you will have to Change how the Sound is being Outputted from Analog to Optical Or (Coax) if that what you want to use. If u dont have the Optical Cable it will Run you about 40$ Cnd for a good TXH one
