New member Username: BerkleebassistBoston, MA USA Post Number: 3 Registered: Jun-07 | So, I replaced my stylus which had broken with a slightly nicer stylus that fit my Ortofon cartridge. However, it now seems that this new stylus has a lot more "give" than my old stylus did, and as such, the cartridge is laying against the vinyl once the needle settles into the groove. I've got a Pro-Ject Debut II turntable, all stock except for the stylus. What can I do to correct for this, as it affects not only the life of my vinyl, but the sound as well (the needle "hears" the rubbing of the cartridge against the vinyl.) |
Gold Member Username: Stu_pittIrvington, New York USA Post Number: 2080 Registered: May-05 | Have you tried decreasing the tracking weight? |
Platinum Member Username: Jan_b_vigneDallas, TX Post Number: 11167 Registered: May-04 | . I would suggest you recheck tonearm balance and adjust the tracking force accordingly. There is no reason I know of that a new stylus, if it is the correct model for your cartridge, should be any different than the stylus you removed. Are you certain it is the correct stylus? Or, are you confusing "stylus" with the entire cartridge? If you replaced the entire cartridge, we have issues to solve. . |
New member Username: BerkleebassistBoston, MA USA Post Number: 4 Registered: Jun-07 | Well, I guess I'll have to dig up the manual to figure out how to decrease the tracking weight; as for stylus v. cartridge, I only changed the stylus. Ortofon's cartridges can use a variety of stylii, so since I had to replace the stylus anyway, I decided to upgrade a little bit. |
Platinum Member Username: Jan_b_vigneDallas, TX Post Number: 11168 Registered: May-04 | . And you went from what to what? http://www.audiophilia.com/features/cartridge_setup.htm |
Gold Member Username: NuckPost Number: 8436 Registered: Dec-04 | Ya lost me a bit, Jeff. Again, the before and after? |
New member Username: BerkleebassistBoston, MA USA Post Number: 5 Registered: Jun-07 | Ok, let's try again. I have a Pro-Ject Debut II. It came with an Ortofon OM-5 cartridge. The stylus was damaged by some carelessness on the part of a friend of mine, so I replaced it with a new stylus, but I decided to upgrade a little bit to the newer OM-5E stylus. Now it seems that this stylus has more "give" to it, and as such, the cartridge is dragging on the surface of the vinyl when I spin anything. So, summary: stock Pro-Ject Debut II turntable originally had an OM-5 cartridge & stylus now has a OM-5 cartridge w/ OM-5E stylus Is still factory setup for the stock OM-5 cartridge |
Silver Member Username: Malco49Baltimore, Maryland Usa Post Number: 112 Registered: May-05 | it might be that some damage was done to the cartridge as well.or the tonearm was knocked out of balance. i recently changed stylus(on pro-ject debut lll) from OM-5 to OM-10,and have had no difficulty. good luck! |
Gold Member Username: Frank_abelaBerkshire UK Post Number: 2323 Registered: Sep-04 | Jeff, As far as I know, an OM-5E stylus is actually an OM-5 replacement stylus. Nothing new or better. Higher up the range would be an OM-10 or OM-20 stylus which can fit any OM cartridge. Since it's effectively the same stylus (and in fact, this would be true of any OM stylus give or take a smidgin), the combination should just work. Therefore there are two possibilities: 1. The suspension on your new stylus is broken (unlikely but possible). 2. When the damage was caused, the counterweight was moved and the arm is causing the stylus to flatten. ...unless, of course, your friend caused damage to the arm too... Regards, Frank. |
New member Username: BerkleebassistBoston, MA USA Post Number: 6 Registered: Jun-07 | That's very useful, thanks Frank. ![]() |
