Dual tens in a box for home theatre
Username: Northerncomfort
Sudbury, Ontario Canada
i recently built a home theatre box with 2 10in. subs and wired them for a 8 ohm load since my amp had a cheap 8 ohm sub already in the home theatre,was wondering what would happen if i wired them for a 2 ohm load?????
Username: Natediggidy
Baltimore, Maryland U.S.A.
Post Number: 21
Quote: "was wondering what would happen if i wired them for a 2 ohm load?????"
Answer: The smell of burned electronics and a hefty repair bill. The lower the resistance (ohms), the more current your amp tries to supply. If it's not designed for this, it'll burn itself out.
How much output are you getting out of your 2-10's? Were you trying for more?
