Have NAD T752... Use Nad 216TXH too?
Username: Oknessad
Post Number: 13
So here's a question for you folks. I have the T752 and am wondering if using the 216 for the front two channels with 120 watts (I think thats the spec) will make any sort of difference over the t752 already fairly powerful 80 watts. I realize that it takes alot of watts to make any noticable sound difference but was thinking that it might be easier on the receiver to let a dedicated amp do the fronts? I am kinda deciding between this and a dvd audio player. John A would probably tell me to go for the dvd audio but since I've never heard it, its hard to say what i'd like better. Any and all comments appreciated! Thanks.
Username: Soccer
Post Number: 98
If you're into that, try also Rotel RB-993/other, you'll find similar priced Rotels with more power and quality than the 216/218, AND smaller in size, tho heavier. Nothing beats trying both side by side preferably at home, and nothing compares to your ears, meaning tastes are very subjective.
Enjoy!
