Bronze Member Username: Jim1961Dublin, Texas USA Post Number: 14 Registered: Aug-07 | I would be interested in any recommendations. Transparency and low distortion and noise are the priorities, lots of bands isnt that neccesary. In fact, a five band would suite my needs. I also have no need for an analyzer or added tape loops. High quality and simple here. |
Platinum Member Username: Jan_b_vigneDallas, TX Post Number: 11144 Registered: May-04 | . This is a job for ... Search Engine! Up, up and click. |
New member Username: KirthiUS Post Number: 6 Registered: Aug-07 | FilterBank is a high-end equalizer plug-in designed to emulate the sounds of ... McDSP's world-renowned emulations of vintage equalizers, compressors, ... |
Bronze Member Username: Jim1961Dublin, Texas USA Post Number: 15 Registered: Aug-07 | My first choice here would be a 2 channel, 2 band parametric eq. Anybody make a reasonably priced unit? |
Bronze Member Username: Jim1961Dublin, Texas USA Post Number: 16 Registered: Aug-07 | Found a 3 band parametric eq for $100. A PreSonusEQ3B. Anyone know about it? http://presonus.com/EQ3B.html |
Bronze Member Username: Jim1961Dublin, Texas USA Post Number: 17 Registered: Aug-07 | also found a 4 band stereo unit, Behringer TUBE ULTRA-Q T1951. Better or worse than the PreSonus? |
Bronze Member Username: Jim1961Dublin, Texas USA Post Number: 18 Registered: Aug-07 | I found a ART dual Tube Parametric EQ for $200 http://www.canadapromedia.com/sales/art/dualtubeeq.htm Im going to buy it monday. Ill you all know what I think of it. Thanks for all you contributions! |
Gold Member Username: NuckPost Number: 8441 Registered: Dec-04 | Jim, where was it 200$? |
Bronze Member Username: Jim1961Dublin, Texas USA Post Number: 19 Registered: Aug-07 | At a local guitar/keyboard shop in Austin, Texas. Its no longer longer there for I bought it. I must say, it meets all my expectations. Very clean and transparent! Theirs another unit online for $350 (new) if someone else wants one. |
Bronze Member Username: Jim1961Dublin, Texas USA Post Number: 20 Registered: Aug-07 | Have to say, this solution turned out well. This EQ (ART Dual Tube) is much more transparent than the Hafler DH-110 pre amp was. The ART, coupled with a Adcom slc 505 passive was a significant upgrade. |
