New member Username: Asz2001Post Number: 1 Registered: May-04 | Hello guys, I'm glad I found this forum...anyways Looking to buy home theater for 80% music 20% movies and 100% TV ![]() I am torn between Denon AVR-1804 and Marantz SR-5400. Which should I buy??? I just purchased Acoustic Research 5.1 speakers model AR HC-6 if that makes a difference. Thank you very much! |
Silver Member Username: LandrovalPost Number: 158 Registered: Feb-04 | I would say that the Marantz takes an easy 6-0 victory over the dull Denon. It has more power, features and connections and it sounds clearly better. Here's a review of SR5400, AVR1803 and three others: http://www.wvip.co.uk/cgi-bin/outputpdf.php?file=HCC/200312/110_HC_1203.pdf |
New member Username: Asz2001Post Number: 2 Registered: May-04 | thanks! |
