Need Help which sub cable??
Username: Dee_seal
Denton, TX
Post Number: 13
I am looking to upgrade my subwoofer cable. I have an ONKYO HT-S760 6.1-channel home theater audio system. I came across the following replacement subwoofer speakers. I need some help in deciding which one to go with? I kinda like 4 because it looks so different, let me know what you think?
Choice 1 :DAYTON SUBWOOFER CABLE 25'
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=181-644
Choice 2: Acoustic Research
http://www.bestbuy.com/site/olspage.jsp?id=1051384792390&skuId=4255923&type=prod uct
Choice 3: Monster THX
http://www.circuitcity.com/detail.jsp?c=1&b=g&u=c&qp=0&bookmark=bookmark_0&oid=5 8770&catoid=-8748&m=0
Choice 4 : IXOS XFK01 SUBWOOFER CABLE KIT
http://www.accessories4less.com/Amazing/itemdesc.asp?CartId=7836521NPK-EVEREST-G X867&ic=IXOS%2DXFK01%2F900&cc=&tpc=
Username: Dee_seal
Denton, TX
Post Number: 14
Choice 4: this is the correct link\
http://www.accessories4less.com/Amazing/Itemdesc.asp?CartId=13636512BYA-EVEREST- OI16&ic=IXOS%2DXFK01%2F900&tpc=&cc=&SR=
They'll all work just fine. I would recommend getting the the least expensive choice.
