Replacement tweeter/s for blown Ditton 15 XR
Username: Chemical_cake
SouthamptonUnited Kingdom
Hi
I have a pair of Celestion Ditton 15XR speakers, one of which unfortunately had a tweeter die the other day. I've checked everywhere, but I'm buggered if I can find a replacement. As my only pair of speakers (I'm a bit of a newbie), I've had to replace it with a completely inappropriate old tweeter found in a box of electrical gubbins, but this is hardly an acceptable long-term solution. I was wondering if anyone could recommend somewhere I might get a single replacement, or an appropriate pair to replace them both with. I'm afraid that other than that it has a fabric dome and 8 ohm impedance, I can't give you any more details.
Any suggestions would me much appreciated.
Username: Stryvn
Post Number: 427
Celestion Consumer Division
Eccleston Road
Tovil, Maidstone, Kent
ME15 6QP UKTel: +44 (0) 1622 687442 Fax: +44 (0) 1622 687981
Free Phone: 0800 731 3410
Username: Nuck
Post Number: 8346
From across the pond, Matt.
Username: Stryvn
Post Number: 430
Look down the road, Matt.
Thanks for the suggestions guys, I'll get on it.
Username: John_a
LondonU.K.
Post Number: 4723
Do it, Matt. I had a similar problem a few years ago and found them very helpful. Kef/Celestion is one of those service-minded companies. Phone, or you could also try http://www.kef.com/support/enquiry.asp
