Off topic but no forum for it...computer speaker opinions?
AdamVerducc
Any of you audiophiles out there use computer speakers? Looking for a good, moderately priced set. Any recommendations? Is the consensus that computer speakers are all just a bunch of junk? Thanks.
I don't think that is the case. Its just that there is no big push for a killer computer sound system. Put your money in a nice home audio entertainment sysstme and if you want, tie them all up using a computer media center.
AdamVerducc
That's what I'm trying to avoid. I have a Denon receiver hooked up to a pair of PSB Alphas as my computer speakers right now. It's a bit too cumbersome. Are any of the actual computer speakers any good?
Personally ive heard the Harmon Kardon Soundsticks and they seemed pretty good to me if u are looking for a 2.1 setup. Though i wouldnt say im a big audiophile, but could tell the difference between a good setup and a bad.
Look into a set of Polk RM6005. Good set of satellite speakers for $300-$400. You also get a free 10inch sub!!
