Best Integraded Amp for Martin Logan Aerius
Username: Davetherave
Can anyone tell me what is the best integraded Amp to use with my Martin Logan Aerius Speakers? I know they need minimum 80 wpc into 8 Ohms and twice their rated wattage into 4 Ohms. I paly Jazz and classical. Thanks
Username: Jan_b_vigne
Dallas, TX
Post Number: 10908
McIntosh MA2275.
What about an Amp that cost less than $2000? Is the Nad C372 or Arcam Diva A90 any good?
Dallas, TX
Post Number: 10909
"What about an Amp that cost less than $2000?"
Shoulda said so.
"Nad C372 or Arcam Diva A90 any good?"
Not with those speakers.
Username: Artk
Albany, Oregon USA
Post Number: 5118
Look for a Krell KAV integrated used at Audiogon or check the prices of new ones. They work well with Martin Logans.
Dallas, TX
Post Number: 10911
That they do. Only problem is they sound like a Krell.
How many sources are you running? If only CD, you could run directly into this and use the front panel gain controls, dual vc's are better than one single with a balance control anyway.
http://cls.audiogon.com/cgi-bin/cls.pl?intatube&1189509919
http://cls.audiogon.com/cgi-bin/cls.pl?intatube&1190670650
http://cls.audiogon.com/cgi-bin/cls.pl?intatran&1190601655
http://cls.audiogon.com/cgi-bin/cls.pl?intatran&1190240864
http://cls.audiogon.com/cgi-bin/cls.pl?intatran&1189748195
http://cls.audiogon.com/cgi-bin/cls.pl?intatran&1189297303
http://cls.audiogon.com/cgi-bin/cls.pl?intatran&1189179410
DINGDINGDINGDINGDING!!!
http://cls.audiogon.com/cgi-bin/cls.pl?intatran&1189105721
Mac, Cayin or Rowland, show those ML's what a real amp can do. Don't get suckered into buying on paper power alone.
Username: Artk
Albany, Oregon USA
Post Number: 5120
"Only problem is they sound like a Krell."
It's to drive Martin Logans. Krell is IMO good enough. And I would rather have the Krell than the Cayin (any Cayin). Again to each his own.
David, If you have interest in tubes you may want to check out Rogue Audio as well.
Jan's suggestion for used Mac is a good one, don't discount the used market.
Dallas, TX
Post Number: 10913
Cayin with ML probably isn't a good idea. Stick with Mac or Rowland.
Username: Nickelbut10
Post Number: 101
I would say get a brand new Pyle Audio amp for 70 bucks.LOL just kidding. My Uncle had, and still has a Rowland. He wont sell it to me. mMmMmM Rowland.
Username: Mike3
Wiley, Tx USA
Post Number: 575
David,
Not an integrated, but I have a line on Rowland Model 7s that may come available soon. Drop me a personal email if you want more info.
I only bring it up because it may be offered within you budget. Maybe.
Username: Nuck
Post Number: 8075
oooooooooooh
hi Michael
Sorry for the delay. I am interested in buying the Roalnd. Can you give me your personal e-mail address so we can discuss details. Thanks.
I noticed that Rowland has an integrated amp with 250 wpc at 8 ohms, 500 wpc at 4 ohms. That should be OK for my Martin Logan speekers! Has anyone heard anything positive about this Amp?
Dallas, TX
Post Number: 10943
"Has anyone heard anything positive about this Amp?"
DUH! Where ya been, David?
Username: Nuck
Post Number: 8113
David, that would be yes.
Rowland is well respected and admired brand.
Username: Nuck
Post Number: 8114
Rowland is a well respected and admired brand.
I just found out the Rowland cost $6,500, so i can forget about that one.
however I found another Amp that is within my budget. Does any one know anything about the 'bel canto e.One S300iu'? It sounds pretty good in the specs. 150 Wpc in 8 Ohms, 300 Wpc in 4 Ohms. i can even hookup my ipod with it!. Thanks
Username: Mike3
Wiley, Tx USA
Post Number: 589
David,
Do you want to see what the speakers are capable of or are you just wanting to buy something and move on?
Username: Nuck
Post Number: 8121
David, if you play mp3's...
I just want to buy somthing decent that works well with my Martin Logan speekers and dosn't cost and arm and a leg. I lke the integrated systems because they are usually more cost effective and take up less space on my wall unit which also has a 37inch LCD and CD/DVD player. My previous amp used with the ML speakers was a old Yamaha.
Username: Db_audiofile
La habra, Ca Usa
Post Number: 31
David,
I several pairs of Martin Logans for listening. I also have a complete Martin logan surround system for 5.1 (Different from my accent I's) Different AMPs etc. If this is also a video system and just audio, Ck out a good Denon. I know my audio file friends are rolling over, but there is very little you will gain by over spending. Before I went to completely seperate systems, I used my AccentI's on the front with Logan Passages for the rear. I used a Marantz- Tuner Pre amp with pre- outs and hooked them up with my Luxman amps. The beauty of this is you still can by Luxman on Ebay. By Luxman before Alps, corp bought them. I use 1976- M-4000's as my amps for music and a Denon reciever (5.1) for video. High-end sound on a realistic budget. I like Krell, but 5 k for an amp?
I am familure with your Yamaha. We sold lots of it! Yamaha used current limiting to keep Its amp stable. Your Martin's are hy-brids. Add the small Martin sub (6 bills retail) big improvment!!
Good luck and tell me how it goes!
your friend,
Db
Post Number: 7
Hey i'm back from vacation and I'm still undecided on what amp to buy. I checked out the Denon but it only has 80 wpc. Seem a little low on power. The ML specs say I need 80-200 wpc.
Has anyone heard of the Bryston B100 SST ?. Would that be a good amp for my Martin Logan speakers?
