Gold Member Username: Thx_3417Bournemouth ... Post Number: 4012 Registered: May-05 | Take a few simple (breezeblocks) and with some plastic of other placed underneath them prevent them from making a mess then place the sub bass on them. If the sub has feet its okay as this will not scratch the surface. If it doesn't have feet place some carpet on them followed by the sub bass. ![]() This was one of the things I tired out since late of last week and thou it was kinder successful at reducing vibrations it wasn't near enough when I got around to playing Return of the Jedi yesterday afternoon. ![]() Chapter 13 The Emperors Arrival all the deep tympani bass was kinder lost due to the placement as I had only played a few films since and I guess some of them didn't have bass between 20 and 40Hz that was deep enough. So after use the SW-Re-mix function on the Kenwood KR-F9050D THX select and sent the screen channel bass to the JBL 4645 where it sounded outstanding with lots of drama in chapter 13 when the Emperor arrives at the new Death Star. Now all I had to do was re-position it which took around 8 minutes played the same scene over again and wow that was better and no vibration that is originally within 2" from the floor surface this produced enormous rattling problems with the floorboards where I forced to reduce the volume be many db, and as you guessed it this would reduce the impact emotional drama of the mix. When Han Solo gets punched after carelessly steeping on a twig SNAP! The stormtrooper gives him one heck of smack that felt better than before yes a few (breezeblocks) can make a bit of difference. ![]() ![]() |
Gold Member Username: ArtkAlbany, Oregon USA Post Number: 5098 Registered: Feb-05 | https://www.ecoustics.com/electronics/forum/home-audio/358112.html Something similar.... |
Gold Member Username: Thx_3417Bournemouth ... Post Number: 4026 Registered: May-05 | Art Yes I've just posted a question about it I like what you did for it very nice. |
Silver Member Username: DmitchellOttawa, Ontario Canada Post Number: 203 Registered: Feb-07 | What the heck is a breezeblock? |
Gold Member Username: NuckPost Number: 8145 Registered: Dec-04 | It loooks to be a paver, or a half paver. |
Silver Member Username: DmitchellOttawa, Ontario Canada Post Number: 210 Registered: Feb-07 | Hmmm. The wife would never go for bricks in the living room. |
Gold Member Username: ArtkAlbany, Oregon USA Post Number: 5136 Registered: Feb-05 | No, mine is a paver. |
Silver Member Username: LeonskiPost Number: 159 Registered: Jan-07 | A brick by any other name......... |
Gold Member Username: NuckPost Number: 8152 Registered: Dec-04 | would smell as sweet as a plump of portland cement with fibrous fillers. Or your choice. |
Gold Member Username: Thx_3417Bournemouth ... Post Number: 4101 Registered: May-05 | Oh you have different names for them in the US don't? |
Silver Member Username: KevincorrFairbanks, Alaska Usa Post Number: 110 Registered: Jul-07 | "...The wife would never go for bricks in the living room..." I got some red brick ones and put them up under. You hardly notice except the sub is higher. Like the ones you would see on a nice garden patio. |
Gold Member Username: NuckPost Number: 8190 Registered: Dec-04 | Cocoon,likely yes. I wouldn't dare put breezeblocks in the boot of the Bentley. More likely to toss pavers in the trunk of the Dodge. |
