Anyone close their speaker baffle/port ?
Username: Akkuzio
Can any1 outhere suggest something to seal or stuff the rear port of my speaker ? I lost the foam plugs that were supplied for my speaker.
I know some people have used socks,cloth or something similar to seal the speakers. Any suggestions ?
My speakers are quite close to the back wall and I would like to reduce the boom or reflection by sealing the baffle. Wonder if i would damage the speaker if i do.. Thanks
Username: Jan_b_vigne
Dallas, TX
Post Number: 10761
You won't damage the speaker by closing the port. It's not an ideal solution particularly when the problem is placement. Go to a fabric store and buy some thick, closed cell foam. Cut to size. Make certain there are no air leaks.
By closing the port you will sacrifice three dB of efficiency in the speaker and you will, if you effectively block the port, raise the tuning frequency of the enclosure giving up bass extension.
Username: Akkuzio
Thanks Jan. Will do.
I'd rather give up a slight bass extension rather than color the sound with cloudy bass since I am restricted by speaker placement issues.
Username: James_the_god
Doncaster, South Yorkshire England
Post Number: 511
"By closing the port you will sacrifice three dB of efficiency in the speaker and you will, if you effectively block the port, raise the tuning frequency of the enclosure giving up bass extension."
That's exactly why I unbunged my ports and moved the speakers away from the walls. Funny thing I noticed was that when I pulled the cloth I used to bung up the ports the bass driver moved inwards!!! This frightened me a little into thinking damage may have been done..
Dallas, TX
Post Number: 10787
You frighten easily.
Post Number: 515
Well..cones are meant to go outwards, not inwards.
Dallas, TX
Post Number: 10788
They go both ways.
Username: Stu_pitt
Irvington, New York USA
Post Number: 1956
Bungs. Going both ways. Whats next?
Post Number: 521
Never new cones moved both ways!
Bungs going sideways perhaps Stu?
