New member Username: Benjamin02740Post Number: 1 Registered: Jul-07 | hey guy's i have purchased a cheap pyle pro amp http://www.radioshack.com/product/index.jsp?productId=2540568&cp=&sr=1&origkw=am plifiers&kw=amplifiers&parentPage=search and i was wondering if it would work with 2 mtx tp112 12 in speakers kinda lost just want for home audio around the house as my yamaha reciever kept shutting off wich is why i bought this any way any answers are great thanks |
Gold Member Username: NuckPost Number: 7752 Registered: Dec-04 | ben, that amp looks about right. Also look into Behringer and Crown if you want more stuff. Watch how the drivers are wired, and note if they are dual voice coil units or not. You should wire for 4ohms minimal, unless you want the Pyle to glow in protect all the time. Good luck. |
Platinum Member Username: Jan_b_vigneDallas, TX Post Number: 10748 Registered: May-04 | . Included on a 1200 watt amplifier, "Indicator lights remind you to reduce the volume when amplifier output is excessive." Ya gotta love it! |
Gold Member Username: NuckPost Number: 7758 Registered: Dec-04 | check engine |
Gold Member Username: NuckPost Number: 7759 Registered: Dec-04 | I miss the 'clipping' light on my old Techics 140 integrated. It could light up a room by itself. |
New member Username: Benjamin02740Post Number: 2 Registered: Jul-07 | ok i guess ill go give it a shot i have not even opened it i wanted to ask around 1st im gunna go see what this sounds like my yamaha kept protecting was annoying any ill see how this goes and thanks for ur time to all that replied |
Gold Member Username: NuckPost Number: 7766 Registered: Dec-04 | give it a go, ben. Let us highbrows know how it goes, please. Andre is waiting, I am sure. |
New member Username: Benjamin02740Post Number: 3 Registered: Jul-07 | well believe it or not to my knowledge it sounded pretty good i put them kiddy cornered in ea of my corners in my room sounded great no clippin light or anything i had it about max volume also. i didnt notice any distortion then i linked it to my yamaha and used surrounds on that and set it all up with a klipsch sub and it sounded even better my neighbors were bangin on my door... lol |
Gold Member Username: NuckPost Number: 7781 Registered: Dec-04 | ben, there's good and theres good enough. If the music makes you pound out power chords on air guitar in your boxershorts, then it is one or the other, and it doesn't always matter which. Have fun! |
