Amp for B&W XT4
Username: Zanax
Hi, I`m considering buying an amp for my B&W XT4s...
They need a high current amp, sensitivity for the XT4`s are 86dB...
I`ve been looking at the NAD M3 and Musical Fidelity A5...
Any experience with one of these with B&W speakers?
Username: Frank_abela
Berkshire UK
Post Number: 2241
Both those amplifiers should have enough current to drive the slightly awkward load of the XT4. I tend to use them with surround amps of lower quality than that without any problems.
Regards,
Frank.
Username: Zanax
Hi, Thanx for fast reply! I really apprecciate it!
I know I didn`t mention it but I was also thinkin about what`s the best match with B&W...soundwise..?
Or is there other amps that I should consider, which would give me "more bang for the buck"..?
Username: Nuck
Post Number: 7717
Zanax, Rotel is a standard pairing with B&W in many shops, as they have been under the same corporate umbrella for a good few years.
