New member Username: SnadderloffPost Number: 1 Registered: Jun-07 | Need help with my first time setup of a goldring GR 1.2 turntable. I am a firsttimer on turntables and didnt get a manual from the shop (!!) so I dont have a clue how to set it up... for now I only get sound from one channel. What can I do to correct it. Other input on setting it up properly would be deeply appreciated ![]() |
Platinum Member Username: Jan_b_vigneDallas, TX Post Number: 10599 Registered: May-04 | . JM, it's called a search engine. http://www.audiophilia.com/features/cartridge_setup.htm |
New member Username: SnadderloffPost Number: 2 Registered: Jun-07 | JV, its called a smart@ss. thanks for the link.... |
Platinum Member Username: Jan_b_vigneDallas, TX Post Number: 10602 Registered: May-04 | . I'm sorry. But you're called stupid! Bet you answer to it too. |
