Hi all........ i have an Energy C9 FloorStanding spk , and the spec reads as 94db and 250 watts , At Present i am driving these with NAD 208THX , Can anyone suggest any other amp which drives the speaker better then NAD. Also suggest me a good amp for C3 stand mount .thanks . dev.
After reading a review of the NAD you have, I'm puzzled why you're not satisfied. What's up?
I have the C5 floorstanders and drive them with a Rotel RX-1052 100wpc stereo receiver...also, the C3 on stands driven by a Marantz SR4320 80wpc stereo receiver. Both sound great...the Rotel is neutral, the Marantz warm.
hi thanks I am satisfied with the set up right now....but i would like to know if there is any other amp which will be better then NAD , i am using Marantz 5400 CD Player kindly suggest be a good cable and inter connects dev.
Nuck u are absolutely right ....my inter connects are not that good , i am planning for some models from Qed or Monster....kindly advice. as for the speaker cables i am using QED silver Anniversary
