Ok, receiver was working fine last night now this morning I turn it on and the Display shows nothing. The power button turns green but nothing shows in the display. Denon's troubleshooting says check the power cord to ensure it's secure. I did this and even changed outlets and still the same.
Is it possible you've switched off the display? I believe the Denon AV receivers have a Dimmer functionality that allows you to set the display to 4 different levels - Light, Middle, Dark and Off.
Otherwise, it sounds broken to me. If the light around the standby button is green, it should come on and display something...anything. But check your dimmer setting first.
Thanks for the reponse Frank. I actually took it back to the shop i purchased it from and they confirmed that there was soem sort of issue. Thye gave me a new one, set it up last night and all is well.
Hi, Mr. Abela's opinion is one I found that works - dimmer control on the receiver could be the main cause why you may not have a display on your receiver. Hope that is all that is wrong with your receiver. I own the 3802. So far, it works very well. Only problem I have with it, which is not DENON's Fault is the FM coax. connection has become obsolete thanks to the digital signal the cable Co.'s have decided to switch over to. Perhaps they should also offer a digital to> analogue decoder of some sort in order to listen to the FM part of the receiver. Like everything else, this would only be temp. til the receiver itself becomes obsolete.
