New member Username: FunkybootyCupertino, CA United States Post Number: 1 Registered: May-07 | I'm building this system for a 22x24' living room: either a Pioneer VSX-1016TXV or a Sony STR-DG1000 I'm looking at the one of the svs surround packages, but I think I'm going to need in ceiling rears. mathing rear athena's or boston acoustic in ceiling surrounds with the svs sbs01's and scs01 center be weak? i'm cringing at the in ceilings, but i have nowhere to reasonably mount good rears... or, another route is 3 athena ws 60's for the front and a couple athena in ceilings for surround plus the svs sub.. any suggestions or alternatives? |
Silver Member Username: GamerdudeOntario Canada Post Number: 503 Registered: Apr-06 | Go with the pioneer, Its heaver and is a better build. Good luck |
Bronze Member Username: DmitchellOttawa, Ontario Canada Post Number: 98 Registered: Feb-07 | I own the Pioneer 1016 - it's a solid unit with good sound. MUCH better than the Sony I imagine... |
Bronze Member Username: KillamabillaClear Lake, TX USA Post Number: 11 Registered: May-07 | http://hsuresearch.com/products/hb-1.html My rec with the Pioneer 1016. The Athena B1.2s are good too, best deal for the money will match the Pio nicely. |
Bronze Member Username: DmitchellOttawa, Ontario Canada Post Number: 99 Registered: Feb-07 | I've been curious about the Hsu bookshelfs. What's your opinion of them? What would you compare them to? |
New member Username: FunkybootyCupertino, CA United States Post Number: 2 Registered: May-07 | Those hsu bookshelfs look nice.. The other issue I'm having is the center. I can't fit a 3rd hsu bookshelf on my mantle, so I may have to go with the athena's b1.2's and a smaller athena center with a couple in ceiling's... Would in-ceiling athena's raise matching issues with the hsu bookshelfs? |
