New member Username: ItalianplayaPost Number: 1 Registered: May-07 | im in the market for getting a car stereo and i am at a dilemma. do I purchase two kicker comp vr 12 inch subs or one 15 inch kicker L5. im trying to figure out witch one will be ultimately better. having one or two. also what are pros and cons. they will be running on a Kenwood KAC-7203 500 watt rms * 1 channel. |
Gold Member Username: WingmanaliveA pic is worth 1000 posts!! Post Number: 6640 Registered: Jun-06 | Try this section. https://www.ecoustics.com/electronics/forum/car-audio/49.html This is "Home audio" subwoofers. ![]() |
Gold Member Username: NuckPost Number: 7329 Registered: Dec-04 | Gee, Paul, I didn't know you even looked here. |
Gold Member Username: WingmanaliveA pic is worth 1000 posts!! Post Number: 6738 Registered: Jun-06 | Lol. I look everywhere. |
New member Username: BikestrikeschoppersFt myers, Floida US Post Number: 1 Registered: Jun-07 | Post in the wrong area but I will answer your question. Kenwood amps have never been very strong no matter what the claim. You will get much more SPL out of the 2 12's rather than the one 15 due to the efficiantciey of the 12's compared to the 15. I believe the 12's will be more efficiant than a 15 when paired together, plus you will have more moving mass. Thus creating higher spl. Also, it will be a cleaner bass. The larger the speaker is, the harder it is to control. In addition to that. I think your amp would be much better suited for the 2 12's in a dual voice coil running 2 oms stereo Than running a mono load with the one 15. |
