Surround & Speaker 'B' hookup
I have 4 speakers. 2 hooked up to 'A' channel and 2 hooked up to the surround channel. My surround speakers are Bose and I would like to use them when playing CD's as well. Can I hookup the surround speakers to the 'B' channel as well?
What I'm asking is. Can I hookup the same speakers to the 'B' and surround chanel without interference from the other? Would I run into a problem if I have output from the surround channel being routed into the 'B' chanel?
Would I need a speaker switch box? Don't really want to buy another set of speakers if I don't need to.
Thanks for any hep in advance
eCoustics
You can hook a speaker up to either the "B" Channel or "Surround" Channel, but not both to the same speaker.
The "B" channel receives the same signal as the "A" channel, but the surround channel is processed by your receiver for rear effects.
