Connection problems for Fisher CA 60 stereo to tv
Username: George_b
I have a Fisher CA 60. I'm trying to put sound from my sterio into my LCDTV TecHDisplay model number 1910 CB. I'm using Xbox cables so it reaches my rather large Fisher stereo. I have the plugs in the Aux ports on stereo and the plugs in the AV inputs yet I have no sound. It is the LCDTV that wont allow the new sound from the stereo since the TV has an amplifier? Any idea would be greatly appreciated.
Username: Project6
Post Number: 13993
Isn't that backwards?
You want sound from your stereo INTO your TV?
If you really wish to do this you need a pre-amp output from your receiver to your TV's audio INPUTS.
If your stereo does not have a pre-amp output you may want to check if it has a TAPE OUT or REC OUT and connect that to your TV's audio input.
Username: George_b
Yea your right, want to use the speakers from my stereo so sound from TV to my speakers using the Aux port from stereo.
Username: Jan_b_vigne
Dallas, TX
Post Number: 10392
Go into the TV's set up menu and switch on the appropriate output (which is wherever you can take an out going signal from the TV, this would not be the "AV inputs").
